does anyone know if the club still has this mount that is needing repaired? Id be interested in maybe purchasing it if its still around.
I’m not sure if you got an answer to your question. I believe that mount is still at CRO in the CONEX. I will ask about it at the meeting this Friday.
Did we ever get an answer on this ?
It’s in the conex, it’s in bad shape. I would not consider it operable. It’s more of a museum piece.
You can have this item if you still want it. It is one of the items that was going to be disposed of once we get a crew together to clean out the CONEX so it can be used for other items that will be used.
Cool well I guess let me know when your putting a crew together and i can help and then haul that home. Thank you.
