It’s been over a year since I did any planetary imaging, but finally got a chance for Jupiter this week. Unfortunately, the seeing wasn’t so good. As a result, the images making up this animation are pretty soft.
Update: 11-25-23
I found additional video that I thought I had lost. Here is another 38 minutes of animation that starts with the last frame of the animation above. It looks like the seeing improved a little for this sequence.
Date and time for this sequence: November 23, 2023 02:00:29-02:38:15 UT
Observing Details:
Seeing: Poor-Fair
Transparency: Good
Image Details:
Animation 1 consists of 14 images. Animation 2 consists of 12 images. Each image is a stack of the best 3000 of 10000 frames.
Each frame 10.07 ms ; Gain 295
Equipment:
Telescope: Celestron C8 (203 mm f/10) operating at f/20 with 2X Barlow lens
Camera: ZWO ASI224MC with UV/IR cut filter
Mount: Meade LXD75 (under renovation)
Capture:
FireCapture
Processing:
Autostakkert3
Registax
GIMP
