Just finished building this bino chair. Can’t wait for some clear skies to put it to use.
looks nice!
This is awesome! How much did it cost you? Is it ona swivel base?
It was just over $200. I already had the chair and bino adapter. It does swivel. I bought a whole sheet of plywood but only needed 2ft x 4ft. Here is the cost breakdown:
| Description | Cost |
| 3/4 in plywood 8ft x 4 ft | 35.88 |
| Lazy Suzan hardware | 21.79 |
| 1-1/2 in x 10 ft PVC (2) | 25.56 |
| 1 in x 10 ft PVC | 8.48 |
| 1-1/2 in PVC elbows (4) | 11.4 |
| 1 in PVC elbows (2) | 2.96 |
| 1-1/4 in x 10 ft steel conduit | 31.35 |
| 1-1/2 in to 1-1/4 in flex coupling (4) | 34.04 |
| 1-1/2 in flex coupling (2) | 10.42 |
| 1-1/2 in pipe strap (2) | 1.56 |
| 1 in pipe strap (2) | 1.56 |
| 3/8 in x 4in hex bolt (2) | 7.6 |
| 3/8 in flat washers (6) | 2.04 |
| 3/8 in hex nuts (2) | 1.22 |
| 1/4 in wire pin locks (2) | 5.94 |
| 1/4 in x 2-1/2 hex bolt | 1.29 |
| 1/4 in flat washers (3) | 1.2 |
| 1/4 in hex nut | 0.35 |
| 8 x 3/4 in wood screws pkg | 2.48 |
| TOTAL | 207.12 |
