So my handheld go-to on my Celestron mount doesn’t have Mel designations, so is they only way to find this cluster is to use RA and Dec or my software pkg that can control the scope? The other name for the Coma Star Cluster is called Collinder 256 which also isn’t on the handheld either.
I checked several of my apps that can control scopes and only found Sky Safari Pro with Melotte 111 in its catalog.
I’ve checked my other astronomy apps, and most only have Melotte 22 and 25 in their catalogs. Or don’t have any Melottes at all. So you’ll probably have to pay for an app that has an extensive catalog.
Thanks Dave. This in-the-sky.org looks great that all these catalogs are in one place! I’ll probably just do a go-to and put in the RA and Dec for Mel 111 and that should take me there. I’ll bookmark the web site. Again, thanks. /Randy
Melotte 111 is located about 2° to the celestial south from the 4th magnitude star Gamma Comae Berenices. Mel 111 is a large, loose open cluster that I have found to be best viewed with binoculars.
On July 7 at CRO, Melotte 111 was naked eye visible appearing as a slightly brighter area in the sky near Gamma Comae Berenices.
